Need Help
Old Apr 17, 2011 | 08:28 PM
Z-28's Avatar
Need Help
Will a rear end from a 1991 camaro fit my 1994 camaro? The 91's rear end has 373 gears on it which I am currently in the process of getting, idk if I should buy new gears and have them installed or get the 91's rear end? Any suggestions ?
Old Apr 17, 2011 | 09:47 PM
Re: Need Help
A 3rd Gen rear will bolt right in to a 4th Gen. But the 3rd Gen rear is at least 3 to 4" narrower, so you will need wheel spacers, or wheels with less backspace. You will also lose your ABS.
And since this isn't an "engine" question, let's move it to the correct forum.
