Do you need a window switch for a lt1 fbody?
Old May 7, 2008 | 12:14 AM
Billet ss's Avatar
I needed one for my impala ss will I need it for my z28(lt1 le2 combo 200 shot)
Old May 7, 2008 | 09:15 AM
Ray@NitroDaves's Avatar
It is always suggested to run a window switch on any nitrous kit.
They are used to prevent activation at low RPM and to shut the kit off before the rev limiter. This greatly reduces your chances of problems.
Old May 7, 2008 | 09:28 AM
Billet ss's Avatar
But will the trans shift without it? I know my impala wouldnt.
Old May 7, 2008 | 12:34 PM
Moshbmx1's Avatar
were you spraying through the shifts?
Old May 7, 2008 | 01:22 PM
If the transmission wouldn't shift under load, it sounds like more of a transmission issue.
Old May 7, 2008 | 01:58 PM
bombebomb's Avatar
Window switch has nothing to do with your transmission I dont think.
Old May 7, 2008 | 07:15 PM
Billet ss's Avatar
There was nothing wrong with the trans it just wouldnt shift if I sprayed through the shifts(first to second)
Old May 7, 2008 | 10:30 PM
Moshbmx1's Avatar
It was probably putting to much strain on the trans trying to pull the hp. I dont think its a good idea to spray through the shifts anyway which is why i have the window switch shut the spray down right before it hits the next gear.
Old May 8, 2008 | 11:02 AM
it all depends on the setup....if it is a DD that is willing to make ET compromises to prolong tanny life, than yes you can shut the kit off before the shift. This does reduce a little stress on transmission internals, but the rpms have allready dropped back into the "on" window before the shift is completed.
If it is a weekend warrior/race car you want to spray through the shift. I have my on point set to 3K and off at 6.8k. Rev limiter is 7k and launch RPM is 4K+ with convertor flash. My kit is spraying before the car moves and doesn't shut off until I let off the gas. This is with a 700r4 tranny with just a few internal mods
Old May 8, 2008 | 03:08 PM
Ive blown up 4 trannys until we finally got the right set-up, and im not looking to add a 5th quite yet
I do understand that...I am currently on version #4...if I ever need #5 it will be a powerglide
Old Jun 6, 2008 | 07:48 PM
Billet ss's Avatar
You guys are scaring me
Old Jun 8, 2008 | 06:52 PM
Moshbmx1's Avatar
No need to be scared Have you had any tranny work done yet?
Old Jun 9, 2008 | 09:06 AM
sorry...maybe I should have pointed out, how I have gone through the transmissions.
Stock the car had a T56. This was on a H/C/150shot combo ran 12.0 @ 120+ (2.0 60') But did break a Spec stg3 clutch in half on a 1-2 powershift.
This combo had a road race suspension setup and was useless at the strip.
I converted to a drag suspension and a 700r4 auto with a 2800 stall. Also was running a 396cid making 422/447 NA and 566/604 on a 150 shot. (HP #'s are from the T56) First tranny died in 2 weeks due to converter failure.....rebuilt the tranny and 2 weeks later the converter failed again. Turns out the flex plate was bent
New tranny has everything that can be done to the 700 and a billet 32-3500 stall. Have had no issues out of this one in 2 years. But we will see how it likes 700+whp .
Old Jun 9, 2008 | 12:59 PM
Billet ss's Avatar
Its rebuilt with a shift kit good parts.
MichiganSkip
Aug 31, 2002 08:52 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
