I GOT MY refund back
Old Mar 11, 2008 | 09:16 PM
camaroLevi's Avatar
Angry I GOT MY refund back
from the throttle body, i went to the place to get my car back finally the guy was putting and trying everything to get it started (tac module/tb/throttle accuator and then the latest today he calls me "i need to put in evap canister for 495$," i said urrrrrrr back up, i can get one of those for 95.00 $ at rockauto .com long story short guy at bad shop says "that was the problem and it would take 5.7 hours to take tank off "(russian accent) i said put my car down now i want my old tb put back on and i even got a new throttle body gasket for 1.21 off rockauto anywho the guy said it would be 20$ for the gasket , fu*k that ! so he put my tb on it started right up i said leave it on dont u turn that off , lets get my refund now ,... it took me 50 minutes to get the refund i hate top auto repair off of northgate in sacramento cALIFORNIA 95833 ,...ANYWHO I WENT HOME and celebrated that i have my tb money and a lil more narrowed down knowledge as to what this starting problem is please help the code was p1518/p0449/p0443 and i know what they are because i have the manual but to which one is my starting problem??
Old Mar 12, 2008 | 12:16 AM
95camaroinok's Avatar
The P1518 would be the first place I'd look. Because if it cant get a correct signal from the throttle body in the first place, it cant get the readings its expecting from the purge valve. Its showing the comm link between the computer and tac to be at fault. Since you have already replaced the Tac, I would say follow the wiring from there all the way back to the computer. Get an ohm meter if you cant follow the wires and find a wiring diagram for the pin-out on the computer plug so you can just check the resistance between the connectors. If that checks out ok, then you will probably need a computer.... UNLESS they either didnt change the tac module or the new one may possibly be bad. Does your scanner give you live data or just codes?
Anyway, if it ends up looking like the computer, find a salvage yard unit so you dont spend a bunch more money on something you might not need. I cant really see it being much more than the computer or the wiring between it and the module with those codes. As far as the purge codes, may be directly related either way. OR could be loose/disconnected corroded, etc wires. Jack up the back of your car and get some jackstands or something so you can crawl underneath. Should be some plugs on the floor pan either right in front or above the axle on the drivers side. Should be two of them, they go to your fuel pump and the purge system. Check to make sure they arent loose or any cut wires or anything like that. Let us know what you find out.
rideordie
Nov 5, 2019 04:52 PM
dgPltt
Feb 11, 2015 07:04 AM
Jan 23, 2015 01:13 PM
warmeck
Jan 20, 2015 10:29 PM
