T Bolt clamps
Old Feb 26, 2008 | 11:17 AM
neil350's Avatar
T Bolt clamps
Looking to redo some stuff and get rid of my worm style clamps for some nicer T bolts clamps. The web site isn't very descriptive on the diameter, all they say is 4inch, 3.5 inch and 5 inch. Now my question is, is that the maximum diameter of the clamp before tightening? Is so, then should I be ordering a clamp .5 inch larger or the size of the the tubbing I need to clamp? Also what size T bolt clamp does the Throttle Body use?
Old Feb 26, 2008 | 12:30 PM
jsetzer's Avatar
I ordered mine from siliconestop.com - They say thiers are sized for the total size - So a 3" pipe with 4 ply silicone will need a 3.25 or 3.5 - Be sure you read all the print whoever you order from.
Old Feb 26, 2008 | 04:31 PM
neil350's Avatar
Thanks, that helps a lot. The place I was looking at didn't have any thing really mentioned just the inch size, not the expanded or contracted sizes. That site pretty much says to a 1/4 inch larger to compensate for the coupler.
Old Feb 26, 2008 | 04:49 PM
jsetzer's Avatar
I usually see it listed for the total size, but if in doubt try to contact the seller/vendor.
Old Feb 28, 2008 | 11:29 PM
neil350's Avatar
Sounds good, I'm guessing for the TB I would need a 4.75 inch clamp then?
Old Feb 29, 2008 | 09:50 AM
jammer94's Avatar
got all of mine off of a vendor off ebay got a good price for like 12-14 clamps all t-bolt.
Old Feb 29, 2008 | 09:58 AM
Sparkz28ss's Avatar
I have used the $10 clamps from burns stainless and I have used the ebay clamps from just intercoolers or ETD motors.
the burns where 3.5" to fit over the pipe and silicon couplers...the ebay clamps said 3" and they fit fine...as for the price...the cheaper ebay clamp had a tabs on the side that keep the clamp from walking when you really crank on them... the high price clamp didnt have that feature.I found that interesting
I wont be buying the $10 ones anymore as its not needed and no real quality difference
Old Feb 29, 2008 | 12:41 PM
jammer94's Avatar
plus if you buy several of them the ebay vendors will give you a better deal and better shiping.
Old Mar 16, 2008 | 05:50 PM
blownbird01's Avatar
Dont know if you guys know, but napa has t bolt clamps for under $4. Me and a few buddies are using them.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
