dumb question
Old Jan 20, 2008 | 06:50 PM
whammer33024's Avatar
dumb question
i just got the pacesetter headers with all the emissions hookups and a y pipe. my question is...if i decided i wanted to delete the AIR can i do that now? i'm going to keep the egr but is there a way i can just block off the AIR or will that **** something else off? haha
Old Jan 20, 2008 | 08:39 PM
Green96Z's Avatar
You can easily delete the AIR system by plugging the 3 places it connects: both headers and the intake plenum. However, it will throw a code on OBD2 systems, so it has to be edited out. I emailed PCMforless about it, and they said they can remove it so it will still pass the plug in for smog. You won't pass the inspection though, so find a place that doesn't do it. I plan on doing it on my next tune. There are a few write ups on removing the system, I believe you have to cut the pipe that runs under the crank pulley in half to remove it.
Old Jan 20, 2008 | 09:15 PM
mrmint69's Avatar
Ebay has plug kits that make it real easy.
http://cgi.ebay.com/ebaymotors/96-97...spagenameZWDVW
Old Jan 20, 2008 | 09:58 PM
moroso99's Avatar
just unbolt the lines from headers, then remove the air assembly. plug up the holes on the headers. get the code deleted and u could remove the fuse for the air pump as well. should take 15 mins tops... save probably 15lbs that air assembly is pretty heavy haha
Old Jan 21, 2008 | 10:21 AM
k awesome. i figured i could i just wanted to make sure. my dad owns an auto parts store and i work here as well so i'm pretty sure i can find something to plug the holes. i just wanted to make sure i wouldn't really mess something up, haha. thanks for your help guys!
Old Jan 21, 2008 | 01:24 PM
Pontiac_97's Avatar
my 1997 didnt throw a code for the airpump when i deleted mine
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
donot_4get
Sep 14, 2002 08:03 AM
