Axle stuck, won't pull out...
Old Oct 1, 2007 | 08:52 PM
95RagtopTA's Avatar
A few months ago, my Pass side axle seal started leaking. Not having time to mess with it, I took it to a shop. The mechanic informed me they couldn't remove the axle because it's bent and that the rear is shot. Fortunately, they were able to bolt everything up and I was able to get the car home (although after sitting overnight I had a quart of Diff. oil on the garage floor ). So, before scrapping the 10 bolt I figured I would try to fix it. Currently, caliper/rotor is off, removed cross-pin bolt and the pin, then pushed axle in to remove the C-clip. Went to pull axle and....it gets stuck about 2 inches out. I can still turn it but it won't pull out. Any suggestions??? Thanks..
Old Oct 1, 2007 | 09:06 PM
mdacton's Avatar
slide hammer.........find out whats holding it, or get nasty with it and yank on it with a slide hammer
Old Oct 1, 2007 | 10:57 PM
Performabuilt's Avatar
Supporting Vendor
slid hammer its binding once your out of the carrier it will come out
Old Oct 2, 2007 | 04:44 AM
95RagtopTA's Avatar
thanks for the replies... Someone told me to go to Autozone and rent an axle puller--would that be the same as a slide hammer?
Old Oct 2, 2007 | 07:16 AM
It is a big slide hammer with a foot on it to attach to the lug studs. You may have some twisted splines.
Junkyard method: attach a chain or stiff rope to a cement block and to the wheel flange of the axle. Use the weight of the block as your slide hammer to give it the extra thump you need to get it free.
Old Oct 2, 2007 | 06:20 PM
95RagtopTA's Avatar
or instead of a cement block I could use the anchor this car has tied around my wallet .... Thanks for the replies guys...
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
