Whats Needed...93 to OBD1???
Old Dec 1, 2002 | 02:12 PM
InjectedSS's Avatar
just like the sub says...is it the same as converting obd2 to obd1? what all will be needed? thanks
Old Dec 2, 2002 | 04:16 AM
Wilson's Avatar
Talking
Well, 93's are OBDI But I think you mean about swapping the 93 ECM (removable chip) to the 94+ PCM (Flash prom) right?
If that is the case you will need the 94+ wiring harness, MAF, PCM and maybe a few other small things. I dont know why you would even consider such a expensive and time consuming swap only to gain 0HP difference from the 93's Speed Density setup. If you compare a properly tuned Speed Density setup vs a MAF setup they would yeild the same HP. Under reallly extreme cases the SD setup will yeild more HP cause the MAF will restrict the amount of air that can be consumed, but I doubt this is your problem.
whitehooptie
Aug 10, 2015 07:02 AM
Pullngz
Jul 26, 2015 05:55 PM
88IROC_Z
Jul 22, 2015 11:38 PM
sfGi8nt
Mar 15, 2004 03:27 PM
T/A KID
Mar 12, 2003 03:37 PM
