Plumbing the fuel side..
Old Jun 28, 2007 | 01:56 PM
tapout911's Avatar
I have a Lonnies dual pump set up and am trying to figure out how Im gonna tap into the system for the Nitrous. If i could do it over I would have went with a single in tank and a stand alone system for the nitrous. Little late now lol. How is every one else doin it?
The feed side is going into a y-block then into each rail. Then it comes out of the rails into each side of the regulator, extra fuel is sent back thru the return. All line are -6.
Nitrous kit is a Nitrous Outlet plate.
Thanks in advance.
Old Jun 28, 2007 | 03:57 PM
Ray@NitroDaves's Avatar
Thanks in advance.
all you need is a -6 manifold and a 1/8x-4 fitting.
the manifold will go inline between the rail and the regulator.
Old Jun 28, 2007 | 10:47 PM
I'd take the nitrous fuel off BEFORE the fuel rails. No need to pass the extra fuel through one of the rails, causing extra pressure drop (variation from first to last injector).
Old Jun 28, 2007 | 10:54 PM
mdacton's Avatar
I used an adapter on my suply before the rail
npt to AN...it has a 1/8" npt in the middle....and put a 1/8" npt to -4 adapter in it.....works like a charm
Old Jun 29, 2007 | 12:49 AM
tapout911's Avatar
Thanks guys. I figured I was making it out to be complicated.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
RichardZ SS
Aug 3, 2002 12:26 PM
