Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Possible fuel problem
Old Jun 26, 2007 | 12:49 PM
n2oCamaro's Avatar
I just discovered today that my fuel pressure falls with moderate throttle. It seems to do it mostly in the lower-middle rpm. Its falling from 39 psi to about 32 psi. The pressure is set to 43.5 with the vac line off. Is this the pump or regulator going out? Fuel filter maybe? Its a Walbro 255 intank and a Holly FPR. I have had the pump for about 5 years. It has always had the infamous problem of not holding pressure with just the key on, but it has never been a problem as far as keeping pressure when the car runs.
Old Jun 26, 2007 | 05:32 PM
What happens to the pressure at WOT/max engine load/RPM?
Old Jun 27, 2007 | 02:12 PM
n2oCamaro's Avatar
It doesn't seem to do it at WOT. The AFR is fine too. I just got to thinking that it could be because the sender for my gauge is behind my fuel solenoid for the nitrous.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
