Battery relocation kit question
Old Mar 12, 2007 | 11:49 AM
94_camm's Avatar
Ok i got a battery relocation kit.now were do i run the power to off the battery?Do i just ground the negative side to the body??
Old Mar 12, 2007 | 11:56 AM
JeremyNYR's Avatar
yes, you ground the negative cable to the body. be sure to clean up the area (sand to bare metal) and bolt it to the body. In my 3rd gen, i was able to find a pre-existing hole in the sheetmetal. The positive cable runs directly to the starter, just as it does from the factory. Be sure to use a grommet when running the positive cable through the firewall so it doesn't eventually cut through the insulation.
Old Mar 12, 2007 | 12:48 PM
BUBBA's Avatar
Just curious: if you run the + side directly to the starter, where is the rest of the electrical system getting its juice from?
Old Mar 12, 2007 | 01:02 PM
BUBBA's Avatar
Oh...never mind---I assume that all the other cables wires remain in place at the junction box.
HectorM52
Jun 23, 2016 08:42 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
RedLineRev
Jan 23, 2003 03:51 PM
PaulN64
Aug 8, 2002 05:39 AM
