Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump
Old Feb 7, 2007 | 06:14 PM
brucetrentcamaro212's Avatar
fuel pump
I have what I think is a fuel pump going bad. I was told that you can cut a hole out of the back of your camaro ( the trunk ) and the fuel pump can be changed from there. Or is the only other way is to drop the exhaust down and the fuel tank to change. Is there any better ways to change. Also my car is stock. I was wandering should I use the stock fuel pump or is there a better one I should use.
Old Feb 7, 2007 | 06:26 PM
OBE1 95Z28's Avatar
If you have a 4th Gen, there's a lot of posts on this topic, I suggest you use the search function.
An aftermarket pump like the Racetronix setup will probably cost less than one from GM.
Old Feb 7, 2007 | 07:05 PM
2000GTP's Avatar
Do a search for the "trapdoor method" you should find plenty of posts going over in detail the procedure to chop an access hole.
Old Feb 7, 2007 | 07:08 PM
thanks guys!! you guys know everything when it comes to f bodies
Old Feb 9, 2007 | 04:48 PM
myslowcamaro's Avatar
if you are too nervous about cutting a hole with the tank right there, (dont want to ruin the lines) you can always drop the rear and cut a hatch for future upgrades/replacement with the rear out.
Old Feb 9, 2007 | 04:52 PM
2000GTP's Avatar
Thats actually not a bad idea considering Walbro/Racetronix recommends you clean the fuel tank prior to installing the new pump to avoid any potential of premature failure. So drop the tank, clean it out, install the new pump, then make the access hole for future access.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
