Torque arm
Old Dec 17, 2006 | 10:40 AM
r.serio's Avatar
Torque arm
Do I really need the torque arm on my car? I'm thinking about going to true duals but . . . that arm!
TIA
Old Dec 17, 2006 | 12:37 PM
teke184's Avatar
what kind of mods does it have? what kind of use is the car for? is there a reason you think a TA is worth buying?
it will boost your straight line traction, as well as help in the corners. but as a first mod...NO WAY. much better things to do before that
Old Dec 17, 2006 | 02:05 PM
r.serio's Avatar
It's all stock. Probably not going to see any track time & it's my daily driver. I guess I will just go with the magnaflow cat back and call it a day. Only mod is a 160 t-stat. I'm going to send out the pcm to maximize performance and that's about it. The car just had a full tune up, msd wires 8.5's, NGK's, delco optispark, water pump & a fuel pump.
Old Dec 17, 2006 | 05:10 PM
I thought you were asking could you delete the torque arm. If so, the answer is "no".... it keeps the nose of the pinion from rotating upward under load.
Old Dec 21, 2006 | 09:08 PM
1989CamaroLT4's Avatar
That's right, your torque arm actually holds the rear axle in line with the rear of the transmission. If you remove it, the rear axle will rotate upward severely. Be careful if you take it off, read the shop manual for the procedures, the rear axle has a lot of tension on the torque arm.
Old Dec 21, 2006 | 09:16 PM
rskrause's Avatar
Moderator
You need the torque arm nearly as much as you need a crankshaft!
Rich
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
