maf question
Old Dec 3, 2006 | 10:46 AM
madls1's Avatar
maf question
dose anyone know if when i take out the screen from the ls1 maf if i can put it back in, or when its takin out it is out for good
thanks
Old Dec 3, 2006 | 02:33 PM
lastZ's Avatar
once it is out it is out.....i took mine out and mangled it all to sh*t........
Old Dec 3, 2006 | 05:30 PM
SSpdDmon's Avatar
Leave it in. Removing the screen will alter the fueling and unless you have access to tuning software, you'll be asking for more trouble than good. It'll lean out the AFR across the board, which will cause the PCM to add fuel at part throttle through the fuel trims. But, the PCM can't see what's going on with the AFR at more aggressive throttle positions (ie. WOT). It will most likely transfer any added fuel to WOT on the assumption that it's lean. But then again, it may not. Leave the screen.
lt1matt
Mar 21, 2015 07:35 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
RedLineRev
Jan 23, 2003 03:51 PM
