Lower Control Arms
Old Nov 22, 2006 | 05:00 PM
GMCAMARO's Avatar
Lower Control Arms
I am installing adjustable LCAs. The question is how do you get the rear end into the proper position. I can not get the LCAs in to the proper place to get the bolts through the holes. There is a trick to everything I must be missing something.
Currently they are the same length as the originals.
Old Nov 22, 2006 | 05:03 PM
teke184's Avatar
muscle the axle around...it will go in...just takes some persuading
Old Nov 22, 2006 | 05:31 PM
Hopefully you jacked the rear of the car, and took the weight off the tires. If not, you aren't going to have much luck getting the bolts in. With the chassis supported by jackstands, and the rear axle supported by a floor jack, it doesn't take much muscle at all.
I was at the track one day and a guy asked me the same question... he was trying to swap out the LCA's with the car sitting on all four wheels. I loaned him my jackstands and floor jack so he could get his car back together.
Old Nov 22, 2006 | 05:33 PM
GMCAMARO's Avatar
The car is on a lift.
So all four wheels are off the ground.
It just seemed harder than it should have been to get the LCAs to line up with their holes.
Old Nov 22, 2006 | 05:36 PM
A "frame" lift?
Do you have a drift pin to help get them started?
Old Nov 22, 2006 | 05:40 PM
GMCAMARO's Avatar
A "frame" lift?
Yes a two post frame lift. Yes, I have a drift pin.
Old Nov 22, 2006 | 06:43 PM
GMCAMARO's Avatar
Just finished, using a pry bar.
DarkKnight
Buyer/Seller Feedback
May 11, 2015 10:03 PM
DarkKnight
May 4, 2015 03:32 PM
thenewkid
Apr 12, 2015 07:42 PM
sseeya
Apr 9, 2015 06:38 AM
thenewkid
Nov 27, 2014 09:41 AM
