Transmission Question
Old Nov 5, 2006 | 05:54 PM
owned94z's Avatar
Question Transmission Question
I have a 94 z28 convertible and i was wondering what kind of transmission do i have?
Old Nov 5, 2006 | 05:57 PM
2000GTP's Avatar
Didn't specify if you have a manual or automatic:
Automatic: 4L60-E (4 speed)
Manual: T-56 (6 speed)
Old Nov 5, 2006 | 05:59 PM
owned94z's Avatar
its an automatic
Old Nov 5, 2006 | 06:09 PM
carbedfourthgen's Avatar
did any other auto come in the fourth gens?
Old Nov 5, 2006 | 06:36 PM
rskrause's Avatar
Moderator
'93's had the non-electronic 4L60.
Rich
Old Nov 5, 2006 | 07:45 PM
the 700r4 right?
Old Nov 5, 2006 | 08:43 PM
rskrause's Avatar
Moderator
the 700r4 right?
Basically, yes. There may also be some differences based on the year, application, etc.
Rich
Old Nov 5, 2006 | 09:56 PM
owned94z has a 94 convertible and his console wher the shifter is only says 2nd D and overdrive (no 1st like any other f body i have seen)
Old Nov 5, 2006 | 11:55 PM
That's because the person who ordered the car did not check the option box for the "performance rear axle" option. As a result, it got a small plastic tab that blocks the selection of "1" (can easilly be removed), the indicator window without the "1", a 2.73 rear axle ratio (instead of 3.23), a 110MPH speedo (instead of 155). Typically, also no Z-rated tires and a speed limiter in the range of 108-115MPH (instead of 255 with the Z-rated tires).
Old Nov 6, 2006 | 12:03 AM
the car shuts of at 110 even with a hypertech chip is there a program (tuner etc) to fix this problem?
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Newgmman
Feb 25, 2015 02:53 PM
Lonemechanic
Feb 19, 2015 10:29 AM
cmdeshon
Jan 4, 2015 11:15 AM
Kyle@CSS
Sep 14, 2002 04:06 PM
