Fuel Pump?
Old Oct 12, 2006 | 02:30 PM
tripdoc6's Avatar
Fuel Pump?
I know this is not a f-body but i have a 94 grand am for a winter beater and it just broke down on me today. I was just driving up to the store and i would push the gas and nothing would happen car was still running just wouldnt go no where then just shut down. I tried to start it again and it wanted to turn over just didnt. It has the 3.1 v6. Im thinking fuel pump. Any other info would be much apreciated thanks
Old Oct 16, 2006 | 12:45 AM
tripdoc6's Avatar
Re: Fuel Pump?
No one has any idea or help with this. i just dont want to go buy a fuel pump for $100 but i think thats what im gonna have to do
Old Oct 16, 2006 | 01:32 AM
Bone Daddy's Avatar
Re: Fuel Pump?
Buy or rent a fuel pressure tester first, and check the fuel pressure. At the same time buy a Hayne's manual, or ask on a GA board to learn the correct ratings for your motor.
If the pressure is too high, it's probably not the pump.
If the pressure is too low, replace the fuel filter and check again.
If the pressure is still too low after the filter install, check the pump voltage.
If the fuel pump voltage is fine, check the fuel pressure regulator.
If all else fails, replace the pump.
If you get the Haynes manual (you should anyway) it will tell you a very detailed way to diagnose fuel problems. The above is just a general guideline.
Possibillity it's not fuel related though, could be a bad 02, cat, or an ignition problem.
Always check Fuel and Spark first, and in that order.
Old Oct 20, 2006 | 08:16 PM
ben petersen's Avatar
Re: Fuel Pump?
I have an 89 Camaro RS. its been sittin for about 3 years all fluids are old. How do I get out the old gas. Ive tried syphoning... almost passed out. the fuel smells expceptionally bad. any suggestions?
Old Oct 20, 2006 | 11:52 PM
Bone Daddy's Avatar
Re: Fuel Pump?
Only way other than a eventual collapsed lung, is to use a siphon pump. Electric if you can find one, but the crank style is the most readily available.
Most times there will still be some gas left inside. If it was a year or so I'd just do a siphon and filter change.. But three years or more?
I'd remove the tank, and have the tank cleaned and resealed. Then I'd buy a new pump sock, and a new fuel filter. That's if I wanted to start it. I don't think I have to mention the oil change, tune-up, or battery check.
Old Oct 28, 2006 | 02:33 AM
wrj69420's Avatar
I have a 1995 camro that will start but dies when you press the gas. I was told that it could be the fuel pump relay,but I don't know where it's at?
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
