Temp gauge stuck @ or below 160
Old Oct 9, 2006 | 11:55 AM
Red95M6Z28's Avatar
Even after the car idles for 20 min the temp gauges NEVER goes above 160. If I remember even when I had 160 thermo in the past it still read a little higher from time to time. Plus the heater does blow heat. Could the gauge be broken completely? It does move....just not much. Thanks.
Old Oct 9, 2006 | 04:05 PM
Re: Temp gauge stuck @ or below 160
Compare the reading on the gauge to the reading on a scanner. That will compare the gauge sensor in the head to the PCM sensor in the water pump housing.
If you have a 160deg t'stat, is should not even start to open until the coolant reaches 160deg, and be fully open when the coolant reaches 180deg.
Old Oct 10, 2006 | 03:27 PM
jarheadjim's Avatar
I had the same exact problem, and the cause was that the previous owner had the cluster out/apart and when he reassembled it, the needle was pinched under the plastic stop. I just pulled the cluster out and reassembled the correct way being careful to not pinch any of the needles and all was well. hope this helps.
Old Oct 10, 2006 | 03:40 PM
Red95M6Z28's Avatar
I have never taken apart the gauge cluster of one of these before? You can pull the needles off and re-attach them? Any how to's? LOL
Old Oct 10, 2006 | 04:08 PM
Testing info for the sensor and gauge.
Old Oct 11, 2006 | 05:57 PM
RE AND CHERYL's Avatar
Your thermostat might be stuck open.
Old Oct 12, 2006 | 08:10 AM
Red95M6Z28's Avatar
I am going to try a new thermostat tongiht.
Wow RE, you really brought that car a long way. Very, very nice!
Reminds me of my old red one
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 23, 2015 08:50 AM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
