Possible Trans Problems.
Old Sep 18, 2006 | 12:30 AM
brendon444's Avatar
Recently my transmission has seemed to be slipping under harder than normal acceleration from a dead stop.
What is happening is when i accelerate through first it seems to start slipping at 3000 rpm then rev up to 4000 then slip back down to normal and acelerate fine, only while acelerating in first gear though. Does this mean my transmission is on its way out or is something else that would cause this.
If so how long can i expect it to last just driving it normaly.
Old Sep 18, 2006 | 05:07 AM
CamaroJosh's Avatar
Re: Possible Trans Problems.
I'm having the same problem... Everyday i pull out onto a busy road usually half throttle and it will slip to about 4k then drop into gear. Then again i have no problem shifting at full throttle and when im driving it easy. I know nothing about transmissions so i'm hoping someone can tell me as well
Old Sep 18, 2006 | 07:19 AM
Might want to mention the year of the car so we know exactly what kind of tranny your asking about.
Why not add a "signature" with basic info about your car - year, model, engine, tranny and any major mods?
Old Sep 18, 2006 | 08:10 AM
brendon444's Avatar
Sorry car is a 1994 camaro z28 Auto.
Old Sep 20, 2006 | 02:55 PM
brendon444's Avatar
ttt need to figure out this problem soon sorry
Old Sep 20, 2006 | 04:18 PM
blown94's Avatar
stupid question, but have you checked the fluid? It sounds like its running out of fluid. whats the fluid level and condition like? Pink, burnt, brown, black, etc. Truthfully, unless its pink, or just a little brown and just varnished, not smoked and stinky, its going to have to come out and apart.
Old Sep 20, 2006 | 04:53 PM
brendon444's Avatar
ya the fluid is a varnished brown color
Old Sep 20, 2006 | 06:31 PM
brendon444's Avatar
Update:
I took the car in to a transmission shop to let the mechanic take it for a drive to see if he could figure out the problem. The car will slip in first and second while taking off hard while in drive or over drive around 3000 rpms. But if you manually select first or second the transmission will not slip while taking off hard. This left the mechanic a little confused. Does anyone here know what could be causing this? Could it be an Electrical problem?
Old Sep 20, 2006 | 08:12 PM
Craddock's Avatar
Don't wait till it gets worse to fix it. I waited till mine got to just having first and reverse and I'm paying out the *** for it now.
Old Sep 21, 2006 | 02:05 AM
brendon444's Avatar
Ya im going to get it fixed soon but would like to no if it is something other than needing a rebuild becuase that is pretty expensive. Im asking why would it slip when selected into overdrive or drive while in first and second gear but not when it is manualy selected into first or second it will not slip yet it is still in the same gear.
Old Sep 21, 2006 | 01:38 PM
Craddock's Avatar
If you go to a reputable shop they'll check for other problems before they rebuild the transmission. When I took mine in they checked for everything else first before they took it apart.
Old Sep 22, 2006 | 12:52 AM
brendon444's Avatar
ya i have an appointment on tuesday to bring it in i was just wondering if anyone on here would no.
Old Sep 22, 2006 | 07:26 AM
Vince @ FLT's Avatar
With the condition of the oil a rebuilt is probably your solution.
Old Sep 22, 2006 | 02:56 PM
brendon444's Avatar
Ya its not as bad as i thought the mechanic looked at it on a white paper and said it looks pretty good was still pinkish.
Fastbird93
Apr 9, 2016 07:01 PM
Knightscrapper
Feb 4, 2016 10:25 AM
Campbellb48
Jul 5, 2015 06:31 PM
Fastbird93
May 22, 2015 08:28 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
