Knock sensor problems (maybe)????
Old Aug 16, 2006 | 11:49 AM
95firehawk's Avatar
When using pcmcomm everything looks alright according to Injuneer's website. However I have some suspicions about my knock readings. Is the knock count reading supposed to be fluctuating while driving? I get a value when I first connect the software but after that it never changes. Also my knock retard has never once changed from 0.0. Is this possible or should I see at least something from time to time? I have no tune that eliminates the knock circuit but I do have the LT4 KM. If their was a problem wouldn't it throw the ses light?
Old Aug 16, 2006 | 12:22 PM
turbo_Z's Avatar
Re: Knock sensor problems (maybe)????
Knock is bad so if you dont see any then everything is fine. I guess if you wanna test it out then put in some 89 octane.
Old Aug 16, 2006 | 01:09 PM
95firehawk's Avatar
Not really interested in testing it out. But I didn't know if my knock count should be fluctuating or not. Whatever it reads when I first connect to my laptop is what it stays at no matter if its at idle, cruise, or WOT conditions.
Old Aug 16, 2006 | 03:01 PM
Typically the knock count will increment up a few thousand on startup, then may not change for the balance of the trip. The knock count can increment wthout causing knock retard, and knock retard can be present without the knock count incrementing.
The knock count field will continue to increment up to the maximum value of the filed (40,000???) and then reset to "0" and start over.
Old Aug 16, 2006 | 04:56 PM
95firehawk's Avatar
Thanks for your input fellas. I am still pretty new at this and want to make sure everything is in top shape before I get it tuned. I just wanted to make sure that what I was seeing is for real. Thanks again.
HectorM52
Jul 30, 2017 11:46 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Nostang 96z
Sep 10, 2002 08:54 PM
NJ SPEEDER
Jul 19, 2002 10:22 PM
