PCM wont communicate with laptop
Old Aug 9, 2006 | 08:08 PM
Red95T/A's Avatar
I just installed heads and cam on mt 95 trans am and we have been trying to tune the car and we cannot get the PCM to comunicate with laptop. We have used 2 different laptops, 1 with LT1 edit and the other with tuner cat and neather will link with my PCM. I have checked all fuses and the ALDL port for bad wires. I programed the car last year and it worked fine. Do I need a new PCM? I am out of ideas so any sugestions would be greatly apreciated.
Lonnie
Old Aug 10, 2006 | 04:18 PM
FireChicken1995's Avatar
Re: PCM wont communicate with laptop
mine was like that and i had to get a new PCM so good luck on that one
Old Aug 10, 2006 | 07:27 PM
JZ28Max's Avatar
check any wiring you may have done since you programed it last. it doesnt take much to cause interfereance with the serial port connection. scanmaster was causing mine not to connect.
Old Aug 10, 2006 | 08:07 PM
Red95T/A's Avatar
One other thing, I hooked up the Snap-On Solus to the port and it read all codes and sensors fine. I am not sure if that matters but the ALDL communicates with it? I have not installed anything new except the new motor with heads and cam.
Thanks for the help guys.
Lonnie
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
