Mad Z28 tune-how much timing to pull?
Old Jun 17, 2006 | 08:31 PM
2000GTP's Avatar
My PCM is tuned by Ion for the premium gas tune so I know he has the timing advanced a few degrees but I am not sure exactly by how much.. I also have the Mallory 685 box that has the built in timing retard. My question is how much total timing will I need to pull out for both a 100 shot and a 150 shot in respect to the Madz28 tune as well? All help is as always appreciated.
Old Jun 17, 2006 | 11:13 PM
camzaro28's Avatar
Re: Mad Z28 tune-how much timing to pull?
i just recently sent him an email about this. for the 93 bolt on tune, he only advances 1 degree.
today i sprayed the 150 at 4 degrees total, which on the mallory showed up as 5.0.
hope that helps
Old Jun 19, 2006 | 11:18 AM
Ask Ion. Only he knows the answer to your question, based on where he set the timing tables.
Old Jun 19, 2006 | 11:31 AM
Loadre's Avatar
As long as it's not detonating on the motor tune then it should always be safe to just pull 2 degrees per 50 hp.
Old Jun 19, 2006 | 03:53 PM
2000GTP's Avatar
I'll do that, I know the poor guy is always busy so I figured this would be a little quicker. Thanks for everyones help.
calaban
May 18, 2020 06:43 PM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
MJ_Z28
Aug 8, 2002 09:07 PM
