Cam Shopping
Old Jun 6, 2006 | 07:18 PM
mook99TA's Avatar
Cam Shopping
I am looking at Lunati cams at these specs
222/228@.567lift and 113LSA RPM range is 2000-6600
or
232/238 intake lift .599 and exhaust lift.601 on stock rollers. 113LSA RPM range is 2400 to 6800
With the last cam will I need different pushrods or will the stock 7.4's work?
I am also looking at the comp cams bee hive springs and hardened push rods just not sure of the size.
Old Jun 6, 2006 | 09:08 PM
Greed4Speed's Avatar
Re: Cam Shopping
You'll be better off running hardened push rods on even stock cams.
I wouldn't run the comp 918's on either, siimply for the fact that you can get a complete set of Patriot Gold double springs (good to .650" lift) w/Ti retainers, seat, locks, and seals shipped for ~$250. I've seen what happens to an engine when those 918's break. 918's max @.6" lift IIRC so cam choice 2 would not be able to use them. Stronger springs with the lighter retianers should last loger on either cam also.
What are you looking for in a cam? Those cams are at the lower and upper end of the spectrum.
Old Jun 6, 2006 | 10:27 PM
GhostZ28's Avatar
Re: Cam Shopping
Ya one will be almost like stock with a small power increase and the other will lope harder and sound and push power like an aftermarket cam should.
the main questions to be answered are:
budget?
power goals? (340-360, 360-380,380-400, 400+?)
Possible head work?
Auto or M6?
daily driver/ weekend warrior?
Emissions standards?
The best idea would be to call a cam manufacturer, like Futral. I talked to them and they answered all my questions!
Old Jun 7, 2006 | 02:55 PM
mook99TA's Avatar
Re: Cam Shopping
car is an A4, possible head work in the future, after my next deployment. Looking for close to 380-400 with out head work. Emissions is not a concern and for now she is a daily driver but after next depolyment weekend warrior
Old Jun 8, 2006 | 07:28 AM
Re: Cam Shopping
In your case, I'd advise going with the larger of the 2
Old Jun 8, 2006 | 09:39 AM
GhostZ28's Avatar
Re: Cam Shopping
you might look into a custom grind as well. Email Allen or John at Futral. They know their stuff really well and you can get some good deals if you mention you're from CZ28. I bought my cam and pushrods for $500 even, shipped.
Old Jun 21, 2006 | 02:38 PM
96LT1TX's Avatar
Re: Cam Shopping
im not trying to be an ***, but isnt 500$ a lot for cam/pushrods? I am hoping there was valvesprings in there too?
Old Jun 21, 2006 | 04:06 PM
GhostZ28's Avatar
Re: Cam Shopping
no actually thats with a discount to me for being a CZ28 member. Their cams are 400 bucks and pushrods were 115. they gave em to me for 500 shipped. Check LS1 cams. generally 350-400ish
Old Jun 21, 2006 | 04:08 PM
GhostZ28's Avatar
Re: Cam Shopping
Then, i paid 250 for springs locks retainers seals, 160 for my used harland sharps, 200 ofr new oversized valves, 180 for head machining/enlarged valves... i'm up to 1300 for my heads/cam with doing my OWN porting, and i still havent bought gaskets, bolts, and timing chain/oil pump.
Old Jun 21, 2006 | 04:31 PM
96LT1TX's Avatar
Re: Cam Shopping
crap sorry, thought I was in the LT1 board lol my bad; our cams are 250+shipping.
Old Jun 21, 2006 | 05:02 PM
SSpdDmon's Avatar
Re: Cam Shopping
What about a 224/224 .581/.581 112 LSA + CC 918's for $325 + shipping? Setup was in my friend's car for less than 1,000 miles. His A4 put down over 360hp on a Mustang dyno with a $h!tty tune. PM me if interested.
Old Jun 21, 2006 | 06:23 PM
Re: Cam Shopping
I wouldn't run 918's on that cam new, much less used. If you don't want to change springs as often get some good doubles. You can get a set with Ti retainers, better locks, seals and seats for $250. You can't even get new Ti retainers for the 918's for that much.
Its a nice grind though. I'm all for inexpensive used cams. Got mine for $85.
Old Jun 21, 2006 | 07:14 PM
mook99TA's Avatar
Re: Cam Shopping
looking for a bit more than 360 and a little more radical cam Thanks though
Old Jun 21, 2006 | 08:42 PM
Demon SS's Avatar
Re: Cam Shopping
for what you have said I would do the 232/238 cam, in our last project car with just heads and cam in an M6 we went 11.4 at 122mph(first time out) using that same cam and stage 2 5.3L heads. car had more in her, but we broke the torque arm and a bunch of outher stuff.
so I would go with the 232/238 cam
I can do a package with
Comp Cams 232/238 .595/.605 113LSA (or any Comp LS1 grind)
Hardened Push rods
Patriot Spring package for
$725.00 shipped to the lower 48 states
Old Jun 21, 2006 | 09:27 PM
Re: Cam Shopping
360 on a Mustang Dyno is more than 360 on a Dynojet in comparison.
rideordie
Nov 5, 2019 04:52 PM
Klypto
Mar 23, 2016 09:05 AM
Dmonty
Jun 2, 2015 11:19 PM
chuyz28
Nov 25, 2014 11:14 PM
