LT1 Edit???
Old May 4, 2006 | 04:31 PM
Dennis93TA's Avatar
LT1 Edit???
I have a '93 LT1 and from what i understand the 94 and 95 use a flash prom. You can't get the lt1 edit for 92-93 LT1 but you can for a 94-95 LT1. So here is my question. Can i put a 94 computer on mine and the delete the MAF and 4L60E(since 93 doesn't have an electronic tranny or MAF). Also would it plug right up to my harness? I want to be able to tune my own car when i want. And not have to pay $500 every time i need a tune. Or is there any program i can get for mine.
Old May 4, 2006 | 05:32 PM
Re: LT1 Edit???
The major mismatch between the 93 ECM and 94 PCM would be the injectors. Your 93 is batch fire, with 1 wire to each bank of injectors, the 94 is sequential fire with 1 wire to each injector. You'd have to change the harness. Then you'd have to address the O2 sensors.... 1-wire vs 4-wire. Probably a few other things.
Old May 4, 2006 | 06:00 PM
Dennis93TA's Avatar
Re: LT1 Edit???
So i did some searching on here about this. I read that the Ostrich is the way to go. It says you can upload new binary. Does this mean "binary code" 1's and 0's? I need a program that I can use. And how exactly does this system work. It doesn't realy go indepth about it. Does it replace the chip totaly? Is the "box" the new chip?
Old May 4, 2006 | 07:25 PM
SABLT194's Avatar
Re: LT1 Edit???
Tunercat makes a good def file for 93's and I believe you can tune on the fly with ostrich & Tunercat RT. When you get a final tune, you'll still have to burn a chip on the Memcal however.
Steve
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
Bando
Aug 2, 2002 02:18 PM
