tapping pin in ecm help
Old Feb 27, 2006 | 08:34 AM
Prorac1's Avatar
I have to tap a pin in the blue connector on the ecm. I opened the back of it up (clamshell) do i have to go any further in or do i just have to put the pin into the little holes. Cause it looks like it has to come apart farther. Thanks Prorac1
Old Feb 27, 2006 | 11:06 AM
madwolf's Avatar
Re: tapping pin in ecm help
You should insert the pin until it comes out just a bit further than the others are and then pull back a bit until it stops. The plastic lip should keep it in place and then the blue cover will keep the lip from moving, so it will stay in place.
Old Feb 27, 2006 | 11:58 AM
Prorac1's Avatar
ok, cool, thanks Ian. Eric
93 RedBird
Nov 15, 2015 08:24 AM
surreybrad
Sep 29, 2015 09:00 PM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
