Need help with 4L60E breaking the pump shaft!!!
Old Dec 27, 2005 | 10:35 AM
whinton23's Avatar
Ok here is the deal I have had the trans fixed twice know and the thing keeps breaking the pump shaft. Is there a reason for this? Like line pressure shifting to hard or maybe tighting the converter to tight I am just at a stand still. Anyone that can help please feel free to put your input in on this.
Billy
Old Dec 27, 2005 | 11:04 AM
12SCNDZ's Avatar
Re: Need help with 4L60E breaking the pump shaft!!!
My guess is that your torque converter was built without a lock-up damper. It's common for some manufactuerers to eliminate the damper, in order to make lock-up apply feel firmer. Who built your torque converter?
Frank
Old Dec 29, 2005 | 05:39 AM
Pro Built Automatics's Avatar
Are you talking about the input shaft that is attached to the input drum?, or the stator shaft that is in the front pump that does not turn? Which one are you breaking?, and when & how does it happen?
Old Dec 29, 2005 | 10:05 AM
rskrause's Avatar
Moderator
As the previous post said, what are you breaking? I am not familiar with the terminology you are using.
Rich
Old Dec 29, 2005 | 11:05 AM
whinton23's Avatar
My converter was built by TCI and I am talking about the input shaft that is attached to the input drum. Its the part that the converter nose slides on to if that helps any better.
Billy
Old Dec 29, 2005 | 04:00 PM
12SCNDZ's Avatar
TCI is notorious for problems with lock-up converters. I'd call them and ask directly if they remove the lock-up damper.
Frank
Old Dec 30, 2005 | 02:55 AM
That is one of the reasons why I will not guarantee one of my units behind a TCI torque converter.
Old Dec 30, 2005 | 10:55 AM
whinton23's Avatar
Thanks for all the help guys I am going to have the converter rebuilt and see if that helps. Any other suggestion will be greatful. Ill keep you guys up to date.
Billy
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:28 PM
thenewkid
Apr 12, 2015 07:42 PM
