908rwhp 908rwtq Speed Inc. single turbo LS1
Old Dec 12, 2005 | 10:10 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Today I just finished up tuning a 6-speed F-body we built with our single turbo system (using TTI race hot parts).
370ci iron block, out of the box AFR 225's, 225/225 113lsa cam, Innovative GT76 turbo with 1.15 R-trim hot side.
Boost was 19psi at peak torque, 18psi at peak horsepower. C16 fuel, 21 deg timing @peak torque 23 deg timing @peak horsepower.
Engine management is BS3, used in conjunction with our plug and play piggyback harness which allows the stock pcm to run the gauges, and if so desired, fans, fuel pump, reverse lockout.
http://www.ls1speed.com/pictures/turbo12_12.jpg
Old Dec 12, 2005 | 10:13 PM
pHEnomIC's Avatar
Re: 908rwhp 908rwtq Speed Inc. single turbo LS1
Wow, crazy high numbers.
Old Dec 12, 2005 | 10:37 PM
corbraeater's Avatar
damn that thing sounds like a beast what do you think in would run in the 1/4
Old Dec 13, 2005 | 06:35 AM
LeftoverChinese's Avatar
Impressive as always sir.
Old Dec 13, 2005 | 07:52 AM
RealQuick's Avatar
Nice! You have a lean spot at 4k rpm though...you may want to look at that.
Old Dec 13, 2005 | 09:10 AM
SantaCruz163's Avatar
Any pictures of the car. Street car?
Old Dec 13, 2005 | 09:12 AM
INTMD8's Avatar
Thanks for the tip. Air fuel on the BS3 showed 11.9-12.0 throughout the entire run.
Here is a plug from that pull.
www.ls1speed.com/pictures/turbo12_121.jpg
www.ls1speed.com/pictures/turbo12_122.jpg
Old Dec 13, 2005 | 09:17 AM
RealQuick's Avatar
So is the BS3 wrong or the dyno's WB??? I cant tell form the plug the difference between 12.0 and 13.0....Either way, I am sure you know what you are doing, just thought I'd point it out.
Jon
Old Dec 13, 2005 | 10:46 AM
INTMD8's Avatar
Jon
The BS3 is correct. I have many dynoruns showing the dynos wideband matching the BS3, this run may have been an anomoly, or the filter in the wideband needs to be changed. (I have not yet checked it.)
Old Dec 14, 2005 | 05:10 PM
LukeZ28's Avatar
Nice and smooth curve! Impressive.
Old Dec 16, 2005 | 08:00 PM
AdioSS's Avatar
West South Central Moderator
Very impressive numbers, but I'd say that the heads need some work.
Highlander
Jan 12, 2020 02:13 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
