Compression ratio on blown Big Block Chevy
Old Dec 6, 2005 | 01:54 PM
davepl's Avatar
With aluminum heads, what's a good compression ratio to run on a blown big block Chevy? All my experience so far has been with LT1 motors, and the reverse cooling probably invalidates a lot of my assumptions.
With a GM502 shortblock and a pair of TrickFlow or AFR heads, I can hit around 8.6:1 off the shelf. I am uncertain whether or not I'll be able to run a decent intercooler yet.
Is that low enough? I'd like to hit around 14psi.
Thanks,
Dave
Old Dec 6, 2005 | 03:51 PM
Ponyhntr's Avatar
Re: Compression ratio on blown Big Block Chevy
What fuel will you be running? Carb'd or EFI? 8.6:1 is a good number for 14 psi on pump gas.
Old Dec 6, 2005 | 05:01 PM
davepl's Avatar
I'll be running EFI, likely a FAST ecm, on pump gas.
Old Dec 7, 2005 | 12:19 PM
master of a-bodies's Avatar
Im running 8.7:1 on my 496 w/brodix heads and 12 lbs of boost, 93 octane pump gas, 30 degrees total timing and 11.2:1 air fuel ratio (blow-thru carbureted)
I dont have a hint of detonation and is an animal on the street, havent got a chance to tune it at the track yet.
so 8.6 is a very good number!
as Im sure your aware, remember to follow the ring manufacturers recomendations for gap on a supercharged engine
Old Dec 8, 2005 | 10:09 AM
camcojb's Avatar
Depends on what type of blower you're going to run. Roots likes 8.5: 1 or so and a centrifugal is happy with 9:1.
Jody
Old Dec 8, 2005 | 11:22 AM
rskrause's Avatar
Moderator
In very general terms, a BB is going to be a little less tolerant of CR than a small block. But the difference is small. 14psi is a lot on pump gas unless you are running an IC and/or water/methanol injection. Even then, the CR may be too high for that much boost.
Rich
Old Dec 8, 2005 | 06:12 PM
Lonnie Pavtis's Avatar
Keep in mind that the carbureted motors are also able to use a little more non-intercooled boost because the fuel vaporization leaving the carb venturies also acts as an intercooler to some extent (similar to how alcohol injection cools the mixture). This allows carbed motors to run more boost (approx 2#) than fuel injected motors for a given octane. Just remember your mixture distribution requires more attention on a carbed motor as the intake manifold is the controlling factor to get the proper fuel into the each cylinder.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
Eric H
Aug 10, 2002 06:39 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
