Think i got an accurate reading of my 6spd trans fluid level?
Old Nov 10, 2005 | 08:26 PM
Donohue96M6Z28's Avatar
well i put the front on jackstands, and then checked my trans fluid, i know that it wasnt level, but when i took the plug out, i could feel trans fluid with my finger, think it was full or no? was the only way i could check it, i know i have a leak somewhere and dont want to be low and mess up my trans, also is that true that if your low on trans fluid that ur shifter stick will get REALLY HOT?
anyhelp is appreciated
thanks
Old Nov 10, 2005 | 09:10 PM
FuryZ28's Avatar
Re: Think i got an accurate reading of my 6spd trans fluid level?
I'm no expert, but I would think the tranny is set up like a rear differential- just add oil 'til it starts leaking out the fill hole...
Old Nov 10, 2005 | 10:07 PM
ya thats true, but the car wasnt level, it was off the ground in the front, not sure if it made a major dfference tho?
Old Nov 11, 2005 | 01:27 PM
FuryZ28's Avatar
I wouldn't suspect it'd make a significant difference, so long as the angle of the vehicle wasn't too far from level...
Old Nov 11, 2005 | 02:02 PM
the jack stands had it about a foot of the ground..
Old Nov 12, 2005 | 11:08 AM
The fill hole is pretty much near the center of the T56. That means that if you raise the front end or rear end of the car, it is still OK to check the level through the fill hole. If its up to the bottom of the hole, its OK. If the car is tilted sideways, you can't check the fluid level correctly.
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
