Dash Plaque
Old Oct 3, 2005 | 08:35 PM
LT-14me's Avatar
Dash Plaque
Alrighty well, i want to add a new dash plaque to my camaro. Now i know i have to remove the plastic housing where the A/C vents are etc to be able to remove it. Question is how would i get it off? I was looking at it the other day and its on their pretty solid. Any advice would help.
Old Oct 3, 2005 | 08:53 PM
crazypurgatory's Avatar
Lightbulb Re: Dash Plaque
It just pulls of.
Maybe a pry carefully with a small screwdriver.
Try not to break a nail.
Chris G.
Old Oct 3, 2005 | 08:55 PM
camaros4ever's Avatar
Re: Dash Plaque
Just pull off the piece around the vents and radio, it comes straight off, then flip it over and you will see some little tabs and just press those and it falls off, I wouldn't use any tools because the plastic can break easily.
Old Oct 4, 2005 | 08:17 AM
LT-14me's Avatar
Re: Dash Plaque
Ok, so i would pull towards me as in me sitting in the drivers seat or i would pull upwards like i was lifting it off. I am just really paranoid when it comes to my car. Thanks
Old Oct 4, 2005 | 10:10 AM
Re: Dash Plaque
Just pull it straight out.
Not toward you just straight out.
Chris G.
Old Jan 31, 2006 | 08:49 AM
KAO 91's Avatar
Re: Dash Plaque
I'm in the process of installing the "Camaro SS" dash plaque for my car as well. I have no problem removing the old "Camaro" plaque with the raised red letters.
For those who have done this mod in the past, did you just remove the old piece and stick the plaque on top of the vent piece, using the self adhesive strip provided? I noticed that when I line it up, there's a very small gap that can be seen where the two "button holes" are. There probably isn't enough space to notice, but I wanted to see if this was normal.
Thanks for any replies!
Old Jan 31, 2006 | 09:25 AM
'99 SS's Avatar
Re: Dash Plaque
I removed my original Camaro SS plaque and put one on with the hp., tq., engine size, etc.
First I used a hair dryer and ran it on high aiming it at the plaque. After a few minutes I was able to remove it by taking a piece of fishing line and sliding it behind the plaque. Be careful removing the plaque as it will bend pretty easily. I cleaned the area and installed the new plaque.
As for the original, I have not placed it anywhere else. IMO, too many plaques, decals, etc. cheapens the look of the car.
Old Jan 31, 2006 | 11:25 AM
KAO 91's Avatar
Re: Dash Plaque
So was there a bracket for the "Camaro SS" plaque? When I removed the rasied, red-lettered, "Camaro" plaque, I noticed that it was about a half inch smaller horizontally than the "Camaro SS".
I think it wood look strange if I filed down the raised letters and attached the "Camaro SS" plaque on top of the old plaque.
Does anyone have any close up pics of the plaque/vent area?
David Dempsey
Mar 12, 2016 12:42 AM
Greg88
Sep 20, 2015 07:14 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
