Water leaking into my interior
Old Jan 31, 2006 | 01:39 PM
Jono's Avatar
Unhappy Water leaking into my interior
My car usally sit in the garage and doesn't go out in the rain, but the last few weeks my car sat outside because I was fixing my girlfriends leaky car. So I went into my car the other day and there was a puddle on the passenger side, the water is coming in from the heater ducting, the waters not coming from the heater core because there is not antifreeze in it. So I'm thinking the drain holes for the cowling must be plugged, but I don't know where the drain holes would be, I took the plastic covers off at the base of the windshield but I couldn't see anything. I was wondering if anyone else had some ideas about where the water is coming from if you don't think it's coming in from the cowling, or where the drain holes are for the cowling.
Jonathan
Old Jan 31, 2006 | 02:48 PM
Z28SORR's Avatar
Re: Water leaking into my interior
The drains for the cowl are on the right and left sides of the car on the bottom just in front of the doors. Usually just a slot where the panels are welded/glued together. Also check you A/C evaporater drain.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
madwolf
Aug 2, 2001 08:32 AM
