motor for boost and N2o
Old Oct 3, 2005 | 07:54 PM
ramair96ws6's Avatar
here is what i have for my car so far
Je custom pistons 15cc dish
hellfire rings
Dyer rods (300m)
race master callies crank
splayed 4 bolt main with billet caps
383ci
Trick flow heads
blower cam cant release specs
chomoly pushrods
titanium retaniers
987 comp springs
FAST computer
72# injectors
full aeromotive fuel system
8an feed
6an return
bmr tank
eliminator pump
D1SC with cog drive
air/water intercooler
hoping for 17-19 psi
NX express N2o kit
going for 650+ on motor blower
800+ on motor ,blower,spray
drive train
street twin
D&D built t-56 (viper conversion)
MMC dynotech driveshaft
moser 12 bolt all options
etc etc etc lol
Steve
what do you think
Old Oct 3, 2005 | 09:00 PM
InsuranceGuy's Avatar
Re: motor for boost and N2o
Nice! Very nice!
Question? Why did you decide to go with the standard
tranny with that killer setup?
Emil:93Z,383,Vortech,NOS,water/methanol,TH-350
Old Oct 3, 2005 | 09:08 PM
Originally Posted by InsuranceGuy
Nice! Very nice!
it was the stongest manual 6 speed D&D could build for the car
it has everything imaginable done to it for strength
Old Oct 3, 2005 | 09:20 PM
Bow94z's Avatar
Sounds like a killer setup...
how big of a shot of n20 are you looking to do?Any pics of your car now.?
Old Oct 3, 2005 | 09:40 PM
the car is back to stock now i just sold all of the old setup off of it
but here is a pic of the outside of the car
http://www.sicws6.com/images/Dry_Lak...%2005%2069.JPG
http://www.sicws6.com/images/Dry_Lak...%2005%2066.JPG
Old Oct 3, 2005 | 10:15 PM
Bow94z's Avatar
nice t/a!
Old Oct 3, 2005 | 10:37 PM
thanks its been alot of work to keep it this condition lol
Old Oct 4, 2005 | 05:13 PM
Ed Blown Vert's Avatar
Holy crap!
Old Oct 4, 2005 | 11:03 PM
LT4ultraZ's Avatar
You will blow it J/K. Give me a call. I will help you get this together. Holly crap Steve by the way when did you start running on FISK.
Old Oct 22, 2005 | 10:57 PM
blown383's Avatar
Nice set up man... now the question is how much $$$$?
Also where are you getting the cog drive for your D1SC? Once again pics of the air/water intercooler would rock!!!!
-B
Old Oct 23, 2005 | 09:03 AM
rskrause's Avatar
Moderator
1. Cog drive = bad idea unless it's a race car only.
2. The injectors may not be big enough.
3. You will need one hell of an exhaust system to avoid choking it off at that end.
4. The CR may be too high to run on pump fuel with that much boost, you should consider water/alcohol injection as an anti-detonation strategy if you are planning on running pump gas.
5. You will need a custom air intake for the SC to see 17-19psi. Even with one, the D1 may not flow enough air to see that kind of boost depending on the rev range you plan to operate in. One of the other problems with a cog is the limited number of belt lengths available will in turn limit the pulley combinations you can use.
6. What are the specs on the "Eliminator" pump? You will need a hell of a lot fuel for this kind of combo.
Rich
Old Oct 23, 2005 | 10:23 AM
blown383's Avatar
I'm going to be running a 383 with a D1 but without the n2o. I don't expect to see 600rwhp so I was wondering if a single walbro intake fuel pump along with 42lbs injectors would cut it?
-B
Old Oct 23, 2005 | 10:33 AM
rskrause's Avatar
Moderator
-B
I think they will be too small.
Rich
Old Oct 23, 2005 | 10:35 AM
blown383's Avatar
Rich
Okay what would be a good fuel pump and injector combination for 600rwhp?
-B
Old Oct 23, 2005 | 10:55 AM
rskrause's Avatar
Moderator
The pump, if it's a 255lph should be big enough if it gets enough voltage. With an AFPR you can get away with ~50-55lb injectors and the pressure cranked up.
Rich
