Anyone else disappointed with Richmond????
Old Sep 28, 2005 | 10:07 PM
redzracing's Avatar
Just installed my 4.10 richmonds and I have an awful gear whine. Ive heard worse but mines pretty annoying. I had the backlash set at .004 also. Anyone else feel the same as me or will pretty much all aftermarket gears give a little noise???? I'm gonna deal with it i guess but I gotta get Ion at madz28 to recalibrate for me first. I was reading where someone who had a gear whine swapped to a aluminum D/S and it wasnt as noticeable, anyone know much about that either??
Old Sep 28, 2005 | 10:35 PM
Bow94z's Avatar
Re: Anyone else disappointed with Richmond????
people have said the alum driveshaft works and has less vibrations...the whine is what you get with aftermarket gears, richmond.
I put motive 4:11's in and after 3 track passes they started to whine on me...thats what happens with the crappy GM 10 bolts.
MadZ28 tune is a good choice
Old Sep 28, 2005 | 11:18 PM
Demus's Avatar
Running synthetic gear oil has also been rumored to increase gear noise.
Did you check the contact pattern after the install?
Old Sep 29, 2005 | 07:09 AM
87DJP2001's Avatar
Richmond Gears are know to be noisy due to the cut of the gear teeth. They are competive racing gears and are not ment for a daily driver unless you like the whine. The dr shaft will not help.
Old Sep 29, 2005 | 07:21 AM
Cmr0z28's Avatar
Competitive racing gears? I personally don't know anyone who HASN'T broken their Richmond 10-bolt gears. I went Strange, along with a few other friends, and our rears are holding up just fine.
Old Sep 29, 2005 | 08:22 AM
LWillmann's Avatar
I've been told that putting the car on a rack and running the car in gear so the driveshaft spins, and spraying a rubberized undercoating will help quieten gear whine inside the car some too.
I was also told that any performance gear is going to make a little noise because they are cut and designed to be setup for strength, which makes the contact a little deeper, so they will make a little more noise.
I can hear my 3.42 Strange ProStreets, but they're not bad at all, IMO.
oldschool
Feb 9, 2016 09:21 PM
warmeck
Jul 17, 2015 01:36 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
