sensor question
Old Sep 16, 2005 | 10:22 PM
saltydog's Avatar
sensor question
just bought a multimeter or voltometer thing and was wondering what should the the following sensors read and what should i set the dail on.
iac valve
tps sensor
manfold temp sensor
mass airflow sensor
and what should the fuel pressure be
my car is in my signature
Old Sep 16, 2005 | 10:39 PM
Re: sensor question
For IAC and temp sensors, go to the "How To" pages on Shoebox's website:
http://shbox.com/1/how_tos.html
Temp sensors = Item #13
IAC motor (its not a sensor, its an actuator with two resistance windings) = Item #41.
TPS has 3 wires. Read the supply voltage between the gray wire and the black wire (should be 5.0V). Then read the signal voltage between the blue wire and the black wire ( 0.20-0.90V at closed throttle. The closed volts + approx 4V at WOT, and a smooth transition between the two numbers as you open the throttle).
MAF output is a variable frequency. Not all meters read "frequency", but many of them do. You will see about 2,800Hz at idle (~ 9gps) and 9,000Hz (238gps) at max rpm on a stock engine. Look for 12V on the pink wire to verify the sensor is getting power.
http://members.aol.com/InjuneerZZ/ScanMast.htm
For fuel pressure, you need a pressure gauge attached to the Schrader valve. 41-47psi at idle with the vacuum compensation line removed (43.5psi is the ideal pressure), reconnect the vacuum line and pressure will drop proportional to intake manifold vacuum.... say a 6 to 8psi drop with a stock cam, less drop with a more radical cam.
Old Sep 16, 2005 | 10:51 PM
saltydog's Avatar
Re: sensor question
thanks for the help
Old Sep 16, 2005 | 10:53 PM
Re: sensor question
I find it can be pretty tough to "backprobe" electrical connectors with meter leads. A scanner is the easy way to read sensor values.
Old Sep 16, 2005 | 10:58 PM
saltydog's Avatar
Re: sensor question
yeah working on buying on of those next.
any recomendations
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
