PCM fried??
Old Oct 24, 2002 | 02:47 PM
carl97ss's Avatar
Unhappy PCM fried??
The car was running fine. I removed my coil bracket to put fresh white silicon paste on the back of the ignition module where it mounts to the bracked. pretty easy to do on a '97. when i bolted everything up, i got no spark from the coil. i did and now the dealership has done electrical tests and we both came up with "replace the PCM." I got a new, reprogrammed for the 396, PCM and still no spark and a "replace PCM." anyone else have this experience? we have power going to the PCM but no signal from the PCM's to the ignition module. Opti and crankshaft sensor are fine. No codes. thanks!!
Old Oct 25, 2002 | 02:44 PM
carl97ss's Avatar
Angry
FIXED... after 3 weeks of me playing with this thing and 6 hours of my mechanics time...or $380 , it was a $.35 electrical connector cap that my Translator Plus would plug into to adjust the timing. I don't run the Translator but, use it to adjust fuel trims and timing, to see how the engine reacts via the Auto tap scanner...haven't touched that connect since June. Never touched it when I did my "white paste" application.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
