Emissions tuning
Old Oct 25, 2002 | 03:29 PM
Draco's Avatar
Emissions tuning
Hi guys,
I need to pass an idle and road simulator emissions test in Vancouver, British Columbia. Any tips on tuning with LT1_Edit to minimize my readings? I would like to make sure I pass well the first time. I have no EGR and a cc305 cam with ported heads. I have header leaks also....
Thanks!
Old Oct 25, 2002 | 05:08 PM
jgeorger's Avatar
Check out my thread:
http://web.camaross.com/forums/showt...threadid=39590
Also, your header leaks could cause your problems, as you might be getting extra O2 in your exhaust, thus causing the O2 sensors to read lean, and the pcm to add fuel. That will cause your HC's to skyrocket. So, how do your BLM's look?
If you don't want to or cannot fix the header leaks, you might want to lock your car into open loop mode and run a lean program, 15:1 or leaner. That in conjunction with the info from the thread I pointed you to should get you to pass.
Joe
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
