Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
can you guess the electrical problem?
Old Aug 4, 2005 | 01:16 AM
kandied91z's Avatar
Talking can you guess the electrical problem?
car dies with no warning.
headlights, marker, dash and map lights all work.
battery is good.
power windows and locks do not work
tail lamps do not work although bulbs are good and fuse works perfect.
all fuses in fuse block are good as well as the fuse breakers. the acc fuse that controls the constants like power door locks is also good.
basically i've lost control of the car. can't start it, fuel pump won't prime, tail lamps don't work when the brake is on. ignition works though and so does the factory neutral safety switch on the shifter yet when i turn the key to run i don't have any of the turn on lead electrical equipment such as radio, fuel pump, etc.
any ideas? it would be greatly appreciated...
Old Aug 4, 2005 | 06:06 AM
OneSickSix's Avatar
Re: can you guess the electrical problem?
Check your ground(s)
Old Aug 4, 2005 | 07:03 AM
Timberwolf's Avatar
I was going to say the ignition switch itself (not the cylinder, the actual switch) but that wouldn't explain the lights and such
Old Aug 4, 2005 | 09:56 AM
95 Z/28 LT1's Avatar
Super Moderator
Bad grounds.
Old Aug 4, 2005 | 10:29 AM
dreamer1q's Avatar
Neutral saftey switch.
Old Aug 4, 2005 | 12:01 PM
kandied91z's Avatar
thanks for the suggestions.
the ignition works as i can unock, turn the wheel and move the shifter.
the neutral safety switch could possibly be bad but that wouldn't explain why the car went dead, if it were bad it just wouldn't restart after shutting it off right?
Old Aug 4, 2005 | 12:21 PM
IROC5.7TPI's Avatar
Have you talked to Greg about it? If anybody would know it would be him.
Old Aug 4, 2005 | 02:04 PM
dreamer1q's Avatar
Nope, my car died like that on the highway before I switched it to a manual. It was the neutral saftey switch. We bypassed it and away I went. After a 100 dollar tow bill of course
Grab a set of gator clips and bypass it once and see what happens.
Old Aug 4, 2005 | 03:36 PM
kandied91z's Avatar
i will, thanks for the suggestion..
Old Aug 4, 2005 | 09:52 PM
Timberwolf's Avatar
NSS going bad doesn't explain the lack of brake lights and radio though
Old Aug 4, 2005 | 10:38 PM
IrocSS85's Avatar
jeff, my first thought too was the ign. switch. but ofcourse like dreamer suggested, that wouldnt account for the taillights. the ign. sw. is made up of several outputs and sometimes (esp. late model vehicles) some outputs will work, and others will not. so the fuel pump wont prime/turn on at all? the pcm controls that. have you hooked a scan tool up to see if you can comunicate with the pcm? its prolly a common power or ground for all these things. but what? time to start diggin in unfortunatly.
chris
Old Aug 5, 2005 | 01:45 AM
kandied91z's Avatar
finally figured it out. after tracing everything in the interior and around the battery i dug into the engine bay. turns out there are two fuseable links of an lsx alternator. having a tech manual would have helped this. anyhow the two help to separate power to the fuse box which is still factory. this should have been noticed when only the constant fuses lit a trouble light but i wasn't thinking.
anyhow one of the two popped. for what reason i have no idea but for now all is well...
thanks for the great suggestions everyone.
Old Aug 5, 2005 | 08:35 AM
dreamer1q's Avatar
Glad ya found it Jeff
Old Aug 5, 2005 | 01:44 PM
kandied91z's Avatar
oh me too, thanks..
liamcg97
Nov 25, 2019 05:55 PM
Red Hawk 94
Mar 18, 2019 04:03 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
97z28k&N
Jan 9, 2015 04:58 AM
