Firewall Hole?
Old Jul 4, 2005 | 11:39 AM
zman28000's Avatar
Question Firewall Hole?
Hey guys,
Just wonderin where u guys ran the Pos. cable for your amps? I can't seem to find a hole anywhere! Well...I haven't taken the dash out either...but was hopin to avoid that
Old Jul 4, 2005 | 02:51 PM
99andMine's Avatar
Re: Firewall Hole?
To get to the one most people use, remove the ECU and you cant miss it. Feel free to clear out the leaves and crap while youre at it. take down the black plastic cover under yur glove box and then fish it through. make sure to tape the wire to keep it water proof. Oh, and I didnt remove my ECU, I just crammed my hand down and pulled it half way up. Youll hafta remove part of the cowling to take it all the way out.
Old Jul 4, 2005 | 06:46 PM
FLOW-MAS-TER's Avatar
Re: Firewall Hole?
hmm.. i found a hole in my firewall ( 94 3.4 v6) on the driver side and fished it through that way. i didn't have to pull anything out either.
Old Jul 5, 2005 | 11:32 AM
97FormulaWS-6's Avatar
Re: Firewall Hole?
Like stated earlier, most people just run it through the PCM/ECU bushing on the PS firewall. Depending on how large your power wire is, you may end up making your own hole. 00 wire doesn't fit well through that grommet
Old Jul 5, 2005 | 12:31 PM
zman28000's Avatar
Re: Firewall Hole?
Thanx for the response.
I went behind the ECU b/c my battery is on that side and the cable wasn't long enough for anything else. Also...for those out there with large hands, you dont have to remove anything to get the ECU out, just takes a little patience The bracket that holds it is just 2 bolts...but it is a tight , tight fit.
Thanx again!
Old Jul 5, 2005 | 01:49 PM
GPZ1100's Avatar
Re: Firewall Hole?
Be careful when loosing up the 2 bolts that hold the pcm bracket to the car.
In doing mine, they were both rusted inplace. I realized this after I snapped the head of one. I let the other one be and instead removed the passenger side cowling (black stuff under the wipers), to gain access to the hole.
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
RobFlag
Aug 29, 2015 11:40 PM
4586
Jul 31, 2015 06:03 PM
gelbza
Jul 12, 2015 08:10 AM
