Plug wire question.
Old Jun 12, 2005 | 11:16 PM
Canuck wita WS6's Avatar
Plug wire question.
I can see the spark traveling through most of my Taylor wires(routed OVC) while i look under the hood in the dark, and was wondering if i should be seeing any at all. I'm trying to track down what is causing popping from the exhaust between each shift, and during deceleration while in gear.
Old Jun 13, 2005 | 01:38 AM
Johnny-Z-Man's Avatar
Re: Plug wire question.
You should be seeing NO blue sparks at all. Where are you seeing the escaping sparks? It may be a bad wire or connection, or if the escaping sparks are in front of the opti-spark unit, I would suspect that as the culprit.
Johnny-Z-Man
Old Jun 13, 2005 | 10:59 AM
Johnny-Z-Man
I can see it travel along most of the wires, and just where a few of them have bends. I guess it's safe to assume that these are junk? I thought Taylor were quality wires...
Well with that in mind, should i try another set of Taylors so i can keep my OVC set-up? Or would i be able to route some other set of wires in this same way?
Old Jun 13, 2005 | 03:23 PM
Most of us run 8mm Taylor wires. I think their a step up from stock.
I would first pull each wire and closely inspect it including the end terminals.
Since you are running an OVC set-up, I would replace them with a new set of Universal Cut-to-Fit wires, however you just may need a end terminal repair kit.
I still would not rule out the opti-spark.
Johnny-Z-Man
Old Jun 13, 2005 | 03:30 PM
ABA383's Avatar
To answer your question about using other wires...Yes, you can use any universal 8mm wire with 90 deg spark plug ends, just get the Taylor Opti-end terminal kit to crimp on to your new wires on the Opti side...
I have heard of the Taylors arcing although I've had mine on for a year with no issues. I'm thinking that they get broken when trying to install the opti boots because they are somewhat hard to slide on without LOTS of silicone spray...Just a thought...If you installed them then you know if you had a problem with the boots...
--Alan
Old Jun 13, 2005 | 04:42 PM
Well opti was replaced just before i ran into this problem, i sure hope i didn't get a crap opti...
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
