1, 2, 3, Drive?
Old Oct 19, 2002 | 09:19 AM
KASR_Z28's Avatar
1, 2, 3, Drive?
Just bought an 00' TA....the shifter has 1 2 3 and then D = does that mean, 3 is drive and D is overdrive? In the old Z28 - it had 1 2 D and OD???
KASR
Old Oct 19, 2002 | 09:30 AM
supersp0rt's Avatar
yes, your first assumption was correct. in the ta, 3=d and d=od
Old Oct 19, 2002 | 11:58 AM
Silver NJ_Z28's Avatar
1 = 1ST GEAR OR LESS
2 = 2ND GEAR OR LESS
3 = 3RD GEAR OR LESS
D = 4TH GEAR OR LESS
Old Oct 19, 2002 | 12:20 PM
Pewter99_Trans's Avatar
When you are driving down the rode running someone from about 60 should you drop it in 3rd or leave it in d?
Old Oct 19, 2002 | 01:32 PM
supersp0rt's Avatar
well, its a general concensus that manually downshifting an auto is not good. however, going from od to d im pretty sure isnt a big deal unless youre at high speeds. lots of auto guys (including myself) leave it in d or 3 while doing our city driving; you have better throttle response and you dont have the tranny shifting as much in and out of od.
Old Oct 19, 2002 | 03:25 PM
6speedZ28's Avatar
Hmmmm, ya learn something everyday. I didn't know Camaro's and T/A's differed in that way. Like my SS has 1,2,D,OD. Interesting!!
Old Oct 21, 2002 | 08:22 AM
KASR_Z28's Avatar
What are the MPH's for each gear? Are they the same as the LT1 setup of GU5?
The reason I ask, is becuz when I had it in the 3 and nailed it from 70 - I got to 90 pretty quick, but when it hit 5.5K rpm, I started hitting the rev limiter.
KASR
Old Oct 21, 2002 | 02:08 PM
supersp0rt's Avatar
you should not be hitting the limiter at 5500. if you have an ls1, your limiter is (or should) set at 6200. you need to have that checked out.
Old Oct 21, 2002 | 02:10 PM
KASR_Z28's Avatar
I'll double check it tonight and see where everything is hitting.
KASR
Old Oct 21, 2002 | 06:41 PM
BlackHawk T/A's Avatar
Rev Limiter is @ 6250 RPM.
Klypto
Mar 23, 2016 09:05 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
