Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
12 volt swap?
Old Jun 10, 2005 | 12:48 AM
mavricki18's Avatar
12 volt swap?
I am about to take the oll powerwheels Jeep out of the attick and swap in my old 12 volt from when i replaced her with the optama. will this give her a little more juice or is this a big wase of time?
Old Jun 10, 2005 | 06:04 AM
QUASAR BLU's Avatar
Re: 12 volt swap?
lol
I thought it said 12 bolt swap at first....
dont blow yourself up!
Old Jun 10, 2005 | 03:13 PM
jm8881's Avatar
Re: 12 volt swap?
Actually you can. My old neighbors pulled a Barbie Corvette out of the trash and put a car battery in it. That little sucker would move when it caught traction. It was haulin around at least 180lbs of person. The motor doesn't like so much power or strain and died in a couple of days.
Old Jun 10, 2005 | 04:18 PM
jp2002ls1's Avatar
Re: 12 volt swap?
This is a camaro forum, you need to go over to the jeep forum for more specialized advice.
Don't plan on the motor lasting too long with a 12 volt. Put a voltage regulator in it so you can run 6 volts to the motor most of the time and 12 volts only when you really want it to cruise. Be sure to wear your seatbelt.
Old Jun 10, 2005 | 05:31 PM
IROC5.7TPI's Avatar
Re: 12 volt swap?
Put rubber bands around the back tires so it'll hook, we had my buddies kids Jeep pulling wheelies down the street with a jump box powering it
Old Jun 10, 2005 | 08:46 PM
mavricki18's Avatar
Re: 12 volt swap?
pulling the wheels off the ground in a powerwheels jeep... sweeet
any one see the new c5R one they have now?
Old Jun 10, 2005 | 09:52 PM
JoeliusZ28's Avatar
Re: 12 volt swap?
my nieghbor did a chainsaw engine swap into one a while back, sadly the chasis didnt hold up to the bumps of his yard at 30 mph
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
