Old gas still good?
Old May 13, 2005 | 01:16 PM
YARDofSTUF's Avatar
Old gas still good?
Another question
so the gas has sat for 3 years or so, when I get my key and everythign in order will the engine fire with this old gas or will it need to be drained?
Old May 13, 2005 | 01:49 PM
teke184's Avatar
Re: Old gas still good?
drain it.
pull the fuel filter and just turn the ignition on. should pump it out.
save it an use if for cleaning stuff
Old May 13, 2005 | 03:57 PM
Did you use a gasoline stabilizer before you put it in storage? If not, drain it as noted in the post above. Don't let it circulate through the system at all. Its not going to be good for anything in the system. Could be "gummy" after all that time.
Old May 13, 2005 | 04:01 PM
YARDofSTUF's Avatar
Nope, no stabilizer. This is something I'll let a mechanic do, just been chipping away at things the car needs done to get it running.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Deadbolt24
Jan 19, 2015 01:29 PM
chevysam
Jan 16, 2015 07:45 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
