Need a new fuel set up
Old Oct 15, 2002 | 04:55 PM
SILVERZZ28's Avatar
You can see my mods on my site. I am running a 200hp 2 stage nozzle kit now and I am burning the number 7 plug off when I use the N2o. I figure that I am not getting enough fuel at the end of the fuel rail. has anyone modded. their ruel rail to cure this problem? HOW?
Old Oct 21, 2002 | 11:22 AM
SILVERZZ28's Avatar
OK somebody isn't telling!!!!!!
Old Oct 21, 2002 | 12:17 PM
Welllll.... #7 is at the end of the line, closest to the return end. But I have seen stock rails support up to 1,000HP without starving #7. Have you checked your fuel pressure? You may have to run in excess of the stock levels.
I had a -6AN fitting welded to the back end of each of the fuel rails. The fuel line splits in a "Y" and puts fuel into the back end of each rail. I had a -6AN fitting welded to the diagonal "cross-over" pipe on the front of the rails to serve as the return line, and hung a Weldon fuel pressure regulator under the cowl to control pressure in the system. In effect, the passenger rail only has to handle about 1/2 of the total flow, rather than 100% of fuel demand plus return. And the drivers side rail sees the same pressure at #1 as the passenger side sees at #2. So far it has provided extremely uniform fuel flow to all 8 cylinders, with a 300-shot on a 381ci engine, total about 800crankHP.
Old Oct 21, 2002 | 03:27 PM
SILVERZZ28's Avatar
What do you think about cutting the( fuel in line) And putting a t fitting there and then running 2 lines to the top of the fuel rail plumbed in the center and still use the factory regulator and return outlet? Or just maybe go to the drivers side rail with 1 line?I Hope you can follow this.
Old Oct 23, 2002 | 01:54 PM
SILVERZZ28's Avatar
Hey fred anymore input on this???????????????/
Old Oct 25, 2002 | 04:06 PM
SILVERZZ28's Avatar
TTT
Old Oct 30, 2002 | 05:36 PM
SILVERZZ28's Avatar
Let me try again
Old Aug 8, 2005 | 09:39 AM
SILVERZZ28's Avatar
Re: Need a new fuel set up
Let me pull this from the grave. I fixed it from burning #7 by putting a crossover in. Now I am burning number 6 cylinder plug. All others look fine. I even switched injectors....
Old Aug 9, 2005 | 11:02 AM
NXRicky's Avatar
You might be getting a poor fuel quality and it just happens. If you want the best fix I would do a stand alone with higher octane so you can run around on regular, and add unleaded race gas on the spray.
Ricky
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
alphaauto
Jan 23, 2015 07:42 AM
