tire rub?
Old Apr 4, 2005 | 09:31 AM
ReaverZ28's Avatar
tire rub?
I had my car full of people and paintball gear and hit a pothole now when all the people are in my car and i take a turn i hear what i think is tire rub from the back left side what should I do?
Old Apr 4, 2005 | 10:00 AM
teke184's Avatar
Re: tire rub?
basically you are experiencing what alot of people do when they lower the car...only yours is due to weight
pull the tire off and try to find the spot that rubbed. if its on the inside of the wheel well you can sometimes take a hammer and pound the metal in to get clearance.
if it's on the fender lip...not much you can do other than roll your fender.
i suggest putting less weight in the car. its not a truck after all
Old Apr 4, 2005 | 11:08 AM
Re: tire rub?
Check the "bump stops".... the rubber rots and falls off.
Are you running stock wheels/tires, or aftermarket?
Old Apr 5, 2005 | 09:46 AM
ReaverZ28's Avatar
Re: tire rub?
im using 18 inch 'vette tires on the back and 17s on the front.
2QUIK6
Sep 17, 2016 02:31 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
colts0455
13
Aug 7, 2015 09:15 PM
Slayer
Jul 4, 2015 03:06 PM
