Question regarding Injector..
Old Mar 28, 2005 | 10:58 PM
Deenasty's Avatar
My car is already tuned for my combo. When tuning the car, We only took it up to 5900rpm.. Now I am turning it to 6500rpm..I am maxing out my SVO 30's and am going to purchase some SVO 42's. Do I have to retune the entire car over, or is some simple changes?
Old Mar 28, 2005 | 11:30 PM
roguedriver's Avatar
Re: Question regarding Injector..
Just need to change the injector constant in your tune for the 42's. I don't know the exact number to change it to, but do a search in this forum. Theres a formula to figure it out and it's real easy. You need to take your fuel pressure into consideration in the formula also. You might even find what number to change it to in your search. Lot of info on here about that.
Ken R.
Old Mar 29, 2005 | 10:19 AM
wicked_95z's Avatar
Square root of operating pressure(43.5 on LT1) divided by the injector test pressure (accel and SVO is 39 psi...I believe) times the flow rate in lbs/hr
square root of 43.5/39 times 42.
Someone care to double check me on this
Old Mar 30, 2005 | 10:44 AM
Deenasty's Avatar
does anyone care to double check this for me..thanks!
Old Mar 30, 2005 | 06:14 PM
95Zman's Avatar
operating pressure (43.5sqrt) devided by svo operating pressure (39sqrt) times the lbh of the injector 42. = 44.35. Should be right not 100%
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
