carburators again
Old Oct 13, 2002 | 09:29 PM
77MadMax's Avatar
carburators again
hey guys, I need some info on my 2nd gen 77 camaro's carb. I recently had to have my carb replaced, and i'm looking to get something with a little more performance to it. I'm looking at a holley carb, right now i've got what I believe is a stock rochester carb, (2 barrel) and I want to upgrade to a holley 4 barrel. is this possible without replacing anything else, i.e. the intake manifold, if not, what would i need to replace. Everything in it is stock right now. Thanks!
-max
Old Oct 14, 2002 | 06:50 AM
Don 79 TA's Avatar
you can use, but not suggested, an adaptor plate.
but since a SBC chevy intake is cheap, especially used, i'd get a performer intake and carb.
you might be able to get a kit from summit or jegs for under 300, including EVERYTHING you need for the swap
you could always search ebay for used intakes
just some thoughts
Old Oct 14, 2002 | 12:31 PM
Damon's Avatar
Sticking a Holley 4bbl on a factory 2bbl intake with an adapter won't help much and it may cause problems of it's own.
You should be able to pick up a used Edlebrock Performer intake online or at a local speed shop for $50-60 in good condition. Or you can buy a complete carb + intake combo from Summit, Jegs, etc. at a discount.
Old Oct 14, 2002 | 05:28 PM
77MadMax's Avatar
well I need to get something to replace the carb I've got now, so what would you recomend i replace it with? As long as I'm going to be replacing it i thought i might get something with a little more power, by the way, its a 305 v8. any thoughts?
Old Oct 15, 2002 | 06:18 AM
Don 79 TA's Avatar
you're stuck with replacing the instake or just a replacement type carb.
i don't see any other way around it.
junk yard? for a used intake?
SBC's are a dime a dozen to get parts for
visit a local swap meet.
Old Oct 17, 2002 | 11:14 AM
Damon's Avatar
A little 600 CFM Holley universal replacement 4bbl would feed that 305 just fine. They are $250 new with electric choke or you can pick one up from just about anywhere used for $75-80 in rebuildable condition, $100-150 in good condition. Just make sure nobody's monkeyed with it. You don't want to deal with someone else's ham-fisted tuning efforts. Get one that's relatively new and never been molested, if possible.
Collinjacobfowl
Jul 30, 2015 09:35 PM
FLIPPINZ28
Apr 5, 2006 11:22 PM
DWray
3rd Gen / L98 Engine Tech
12
Oct 21, 2003 11:00 AM
97ramairtransam
Aug 13, 2003 10:03 PM
cory215
26
Feb 27, 2003 05:47 PM
