Do I have to change or reprogram my stock computer after I put a 383 crankshaft in?
Old Mar 23, 2005 | 07:50 PM
jamieSS's Avatar
Question Do I have to change or reprogram my stock computer after I put a 383 crankshaft in?
I have a 1997 Camaro SS LT1. I'm rebuilding the motor and plan on putting a 383 crank, will I have to reprogam or replace my computer? How much will the 383 crank help?
thanx alot,
Jamie
Old Mar 23, 2005 | 11:18 PM
Re: Do I have to change or reprogram my stock computer after I put a 383 crankshaft in?
A 383 crank will give you 33 more cubic inches of displacement. As a minimum, you need to tell the PCM the new cylinder volume. What else are you changing (besides the obvious - pistons)? If you alter the cam or port the heads, you will have more changes to make.
Need more info to accurately answer the question.
Old Mar 24, 2005 | 09:49 AM
WS Sick's Avatar
Oh yeah, the stock tune will run it so lean that its dangerous (for the life of your engine and pocketbook)
Old Mar 24, 2005 | 08:43 PM
jamieSS's Avatar
I just turned 15 so i am kind of new at the whole car scene so i don't know what else i'm gonna do. Do you have any suggestions for some bolt on's?
thanx,
Jamie
Old Mar 25, 2005 | 09:02 AM
WS Sick's Avatar
I would start with the simple stuff, Cold Air Intake (CAI) , a 3 inch cat-back exhaust system by a reputable company (Hooker, flowmaster,SLP,Magnaflow, Borla,etc), Then get a tune and an appropriate thermostat. At that point I'd see how you liked it and your comfort level.
Old Mar 25, 2005 | 10:19 AM
Blue89Bird's Avatar
I hope you realize you cant just "put in a 383 crank". It requires machine work and a host of other things. If you want to rebuilt your 350 as a 383 youre going to need a host of other things to go along with it, none of which are cheap. Expect a minimum of 5000 for a "budget 383" not to mention the additional HP will easily tear up your rear end if you plan on racing it. If its a 6 speed youre going to need a new clutch at the minimum to hold all that power also. You're also going to need a tune like you asked to safely run it, a mail order tune will get you running, but a dyno tune would be much better, and much more expensive.
Old Mar 25, 2005 | 07:13 PM
jamieSS's Avatar
I'm getting all the machine work done to the motor this week, and we've already ordered the 383 kit from summit. My friends suggested i put some pullys and a new camshaft in along with the new computer. Is that a good idea? What read end modifications would i have to make for racing. I've already raced one of my friends with a mustang gt and he killed me in the quarter mile.
Old Mar 26, 2005 | 09:57 PM
arnie's Avatar
Originally Posted by jamieSS
I just turned 15 so....
Mississippi huh?
Old Mar 27, 2005 | 09:00 PM
jamieSS's Avatar
What does "Mississippi, huh?" mean?
Old Mar 29, 2005 | 10:42 AM
NastyCamaro's Avatar
look at what he quoted ....you said you just turned 15 ....so how did you race a mustang? you don't even have a liscence
Old Mar 30, 2005 | 01:11 PM
jamieSS's Avatar
You get your licence when you are 15 and 6 months in mississippi.
Old Mar 30, 2005 | 04:53 PM
jamieSS's Avatar
Angry Re: Do I have to change or reprogram my stock computer after I put a 383 crankshaft in?
What exactly are the steps you have to take when replacing your computer? In a thread at the top of the page someone said that the new computer or tuning will only be a start! What exactly are the steps after that?
Old Mar 30, 2005 | 05:21 PM
Blue89Bird's Avatar
YOU NEED TO USE THE SEARCH BUTTON
From the main forum page: http://web.camaross.com/forums/
Click on "Search" its on the top on the red bar, right between New Posts and Quick Links
Type in computer, reprogram, ecm,ecu, whatever you will find enough info to keep you busy for hours
Old Mar 31, 2005 | 04:43 PM
WS Sick's Avatar
Goto the LT1 tech section and ask what all should be done in an LT1 to accompany a 383 shortblock.
(Higher flowing heads, optimum cam, larger injectors, free er flowing intake system and exhaust system etc.)
HectorM52
Jul 30, 2017 11:46 AM
HCz28
Feb 15, 2015 03:01 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Jul 4, 2005 05:00 PM
