Custom pressure side & suck side piping
Old Feb 28, 2005 | 07:12 PM
Schurters LT1's Avatar
Is there a better way, or a way to get more air flow from the charger to the TB..custom 3" piping ....
How many people have made a 3.75" (T-Trim) pipe to feed the SC and what air filter.
Or what are some better way to free up BOOST...
Old Feb 28, 2005 | 09:46 PM
engineermike's Avatar
Re: Custom pressure side & suck side piping
I played with this a bit and found that any imprevements UPSTREAM of the blower do far more good than improvements downstream. I build a mandrel-bend 3.5" inlet pipe for my T-trim and gained about .5 psi. Then, I removed the whole inlet pipe completely (let the S/C draw from atmosphere) and gained another >1 psi.
I fixed the whole situation by using a 5" mandrel bent inlet pipe on my turbo.
Mike
Old Feb 28, 2005 | 10:37 PM
Mike, where did you get the 3.5" pipe ? do you haae a parts list. Would this be a problem for the maf sensor going from 3.5" to 3" back to 3.5"....Did you not have an air filter on your SC...
Old Feb 28, 2005 | 10:48 PM
I bought the 3.5" mandrel bends from a local Deisel truck shop called Margot's, but you can get them here also:
http://shop.airflowonline.com/Mercha...ory_Code=9DSR1
When I ran without a pipe, there was no piping, MAF, or air filter. The MAF was downstream of the supercharger. I tried relocating the MAF only and found no gains.
Mike
Old Feb 28, 2005 | 11:04 PM
What kind of room is there with the 3.5". could you fit a 4" in there....no one makes a 3.75" do they?
Old Mar 2, 2005 | 10:12 PM
Is there room for a 4" 90*..., I would like to make everything 4"...can this be done any one got pix....
Old Mar 2, 2005 | 10:16 PM
A 4" 90 might fit, but it'll have to be a miter bend, as no one makes it with a tight enough radius.
Old Mar 4, 2005 | 06:35 AM
john35thss's Avatar
I had to miter 3.5 tubing to get a good fit, but I have tpis long tubes that drop # 1 farther forward, If I could have used 4 inch would have bought a y trim insted of the T I bought in sept.
John
Old Mar 4, 2005 | 08:48 PM
97WS6SCharged's Avatar
I don't know if you'll be able to find 3.75" pipe, but K&N makes filters with flanges up to 6".
http://www.knfilterchargers.com/search/univcone.aspx
Old Mar 4, 2005 | 09:09 PM
Lonnie Pavtis's Avatar
You can make a continuous 4" inlet tube from standard mandrel bends without any miters (all smooth flowing segments) It took (4) 90's to build it & it was frustrating to say the least. Connected it to the blower w/ a cobrahead.
It clears 275/40 tires along with the sway bar & fits above/behind the fenderwell/louvered undertray. No digital camera at the moment, so I cannot post a picture. It can be done, just takes some creativity.
Good luck.
Old Mar 4, 2005 | 09:14 PM
I'm too lazy for all that. I'm just going to flare the end of my 3.5" pipe to 3.75" to connect to my T trim. Quick and easy.
Old Mar 4, 2005 | 10:00 PM
What is the cobrahead who makes this any links to a pix...
Good luck.
What kind of 90's(how tight is the turn)
Old Mar 9, 2005 | 06:52 PM
john35thss's Avatar
The cobrahead is right at the inlet of the supercharger, I think powerdyne uses one in there kits.
That was where I had to use all the mitered pieces right off the charger to clear the header than the steering rack and swaybar I think I used like 4 small pieces of tube all at just the right angle , the rest was a piece of cake.
John
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
spearous
Jan 12, 2015 11:03 AM
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
