Turbo Question
Old Mar 8, 2005 | 09:13 PM
JuicedSC's Avatar
Turbo Question
I just had a set of custom turbo headers made, finally got a chance to install them and realized the the oil return from the turbo is lower than the oil pan. Is this going to be a problem, if so how big of one ? Will I be able to run this as is without destroying anything, or will I need to add a remote pump to bring the oil back to the pan ? The line only needs to be about 18 inches long also. Any information would be appreciated, just trying to find out before I burn anything up. Thanks
Mike
Old Mar 9, 2005 | 01:53 AM
sleepybu's Avatar
Re: Turbo Question
you'll need to add a remote pump to bring the oil back to the pan
Old Mar 9, 2005 | 09:46 AM
mongse_1's Avatar
Re: Turbo Question
Yeah, a simple Tilton scavanging pump will work fine.
Should've taken the pan level into account when building the headers. Chalk it up to a lesson learned I suppose.
Old Mar 9, 2005 | 06:24 PM
JuicedSC's Avatar
Re: Turbo Question
If I were the person builing the headers I would have, thats what I get for trusting someone to know what they are doing.
Old Mar 9, 2005 | 07:51 PM
JuicedSC's Avatar
Re: Turbo Question
Would you happen to know the tilton part # for the pump ? Would the pump also have to be mounted lower than the turbo, or could it be placed above it ?
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
blac94Z
Jan 22, 2015 11:19 PM
