How much timing retard with 13:1 and 110 oct.
Old Feb 8, 2005 | 06:27 PM
n2oCamaro's Avatar
I will be dyno tuning soon starting with a 150 shot. I was wondering what would be a good starting point with retard. I wasn't sure if the same general retard guidlines applied when running high compression and high octane.
Old Feb 8, 2005 | 08:28 PM
94Zpower's Avatar
Re: How much timing retard with 13:1 and 110 oct.
I could be wrong but with 110octane and a 150 shot I would think you should be fine... but you could knock off 2 deg to be safe.
Old Feb 8, 2005 | 09:15 PM
rskrause's Avatar
Moderator
The way to use the dyno is to sneak up on it. Don't forget, timing will change the AF ratio. Start safe: rich without much timing. Maybe 22-24 degrees. See what effect small changes have. Listen carefully for detonation, don't be afraid to pull a plug or two(assuming you know the fine old art of plug reading).
Rich
mikey4play
Mar 15, 2015 11:45 AM
nikolt1
Feb 27, 2015 09:10 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
bee20e
Parts Wanted
Nov 27, 2014 05:20 PM
