Qa1 generation F coilover adjust ride height
Old Jan 4, 2005 | 10:11 PM
AlmostfastLT1's Avatar
What was the easiest way to crank up the adjustable shocks. My ride height is way off and the more I crank eventually the spring will keep on compressiing and it will be hard to continue raiseing the shock.
Help needed, what do you all do?
Old Jan 4, 2005 | 10:33 PM
OBE1 95Z28's Avatar
Re: Qa1 generation F coilover adjust ride height
I coated the flat washer, both sides, located under the spring with antiseize grease. This eliminates the binding. Some people have purchased a thrust bearing and located in this same spot. The grease worked great for me.
Old Jan 4, 2005 | 11:06 PM
I will get some of that tom cause I have alot of rasing instore.
asilomar244
Jul 12, 2015 05:53 AM
mrwz28
Jul 8, 2015 09:11 PM
cmdeshon
Dec 12, 2014 10:51 PM
Espo
Aug 22, 2002 06:57 PM
MBonZ28
Jul 30, 2002 11:42 AM
